air starvation
air starvation
Postby Teglease » Thu Aug 20, 2015 7:27 am
Hi' I have a 1960 s2 Li 150 with s3 carb, the problem is it won't run with the filter rubber on( I have removed the filter), it runs fine without the rubber,
so why is it being starved of air ?
Teglease
Re: air starvation
Postby Storkfoot » Thu Aug 20, 2015 8:16 am
The engine craves more air because your carb settings are too rich?
Re: air starvation
Postby hullygully » Thu Aug 20, 2015 3:00 pm
check your air filter plus your air scoop
Re: air starvation
Postby Covboy » Thu Aug 20, 2015 6:14 pm
Hi
I had a similar problem when I put a s3 18mm carb on my s2 150.
I gather that the neck of the s2 airbox is smaller than the s3
I removed the baffle from the airscoop and drilled out the airbox and it runs well now.
Not saying it will fix yours but it worked for me
Users browsing this forum: Baidu [Spider] and 89 guests
