Indicator question
Indicator question
Postby Jono » Sat Jul 18, 2015 4:06 pm
Have just fitted LED indicators to my GP fed from battery and have a issue?
The indicators are rated 2 Watts each and have used a 2 pin relay/switch which works great . Indicators flash ok and are bright the only thing is that when they are off between on flash they are still slightly illuminated.
Should this be the case or if not how do I resolve ?
Any help would be appreciated.
Jono
Jono
Re: Indicator question
Postby Jono » Sat Jul 18, 2015 4:36 pm
Up date - tried direct feed to indicators and they work fine so switch is ok, must be relay giving a low feed when it should be off.
Can anybody recommend a suitable 2 relay that will work and a source of supply, guess what the relay I have is a eBay special.
The issue is that by staying partly lit it does not give best contrast of on/off to indicate clearly intended direction change.
My setup is 2 LED indicators per side of 2 Watts each and a single warning lamp 3 Watts (with a Diode in each feed from either side.
Jono
Jono
Postby MK Monty » Sun Jul 19, 2015 1:49 pm
I would just add a normal bulb to the circuit if it works Ok its a flasher rating problem. If so you need to change the flasher
Had a look on Ebay for the one I used but its not on. Mine had a built in buzzer But if you do a search look for anything that doesn't say Resistor (built in etc),adjustable They rely on the load to determine the flash rate or you need to adjust it. Even some marked as for LEDs are the same you may have to use resistors to get them to work on LEDs. these all negate the reason we are using LED's and the resistors take the wattage back up to 20+ watts per lamp and we aint got the power to spare.
Look for LED and digital flasher units
This is not the one I used and is a bit more expensive than I paid
http://www.ebay.co.uk/itm/DIGITAL-UNIVE ... 1c4f6906c9
MK Monty
Postby Jono » Sun Jul 19, 2015 6:52 pm
Thanks MK Monty
Have tried an extra bulb but still the same situation the indicators flash but still are dimly lit when they should be in off cycle, bleeper works ok.
Lights work fine when fed direct from battery via direction switch.
Have emailed Supplier suggesting the flasher unit is faulty and asking for a replacement as it was sold as an LED Flasher Relay that appears not to fully break the circuit when it should be off.
Will be interested to receive Suppliers comments.
Jono
Jono
Postby Donnie » Sun Jul 19, 2015 7:12 pm
I suspect theres something in your wiring, ,likely in your reistor / diodes.
mines normal 3w bulbs using an led type relay and all worked beautifully, except the warning bulb. I worked out (with a lotta help from here) that i needed to do the diode thing to ensure leccy flowed correctly and didn't cross over. Once sorted that it was all good. It sounds like you are having similar issues but with the whole setup and not just the warning light.
Donnie
Postby Jono » Sun Jul 19, 2015 7:53 pm
Thanks all, just had another play with set-up and introduced a 5 watt bulb into circuit and all seems well,anything less then problem starts over. Ideally I now need to find a warning light in excess of 5 watts .
Anybody got a view on how I could introduce required load without having mega size warning light.
Jono
Jono
Postby MK Monty » Sun Jul 19, 2015 8:21 pm
Your flasher needs a load as I expected. Maplins or eBay ask or search for say a 10w metal clad resistor. Or indicator resistors. Plenty of different sizes available. don't forget a resistor of whatever rating is the same as having a normal lamp on so you are not getting the full benefit of using LED's
MK Monty
Postby Jono » Sun Jul 19, 2015 9:24 pm
Thanks MK Monty
Will be on Bus to Maplins in the morning.
Had a quick look on line at Maplins and can only see Resistors that are not "metal clad" must it be so clad?
Once again many thanks for your help greatly appreciated.
Jono
Jono
Postby MK Monty » Sun Jul 19, 2015 10:03 pm
http://www.ebay.co.uk/itm/10W-Aluminium ... 43d4ac0d97
You are looking for something like this. basically a resistor takes the place of your extra lamp, the voltage/wattage is used up and transferred as heat so these help dissipate the excess heat, they may have wirewound resistors but put them someplace out of the way of other wires, look on those like the bar of an electric fire, they can get more than warm
MK Monty
Postby missing lynx » Tue Jul 21, 2015 6:43 pm
be careful were you put the resistor as they get hot
Postby Jono » Tue Jul 21, 2015 7:06 pm
Thanks to all for help , installation now complete just waiting for delivery of Resistor to get loading correct for flasher requirements. Intend to install Resistor behind horn cast attached to frame/leg shield securing bolt well away from loom & cables with plenty of air space.
Jono
Jono
Users browsing this forum: Google [Bot] and 57 guests
