by Rich Oswald » Mon Jun 23, 2014 6:48 pm
A pal has just had a small block Mugello 200 fitted and although it runs fine he is getting a lot of vibration from the engine. He has changed the engine mount (BGM's) and there was no improvement but also has noticed a lot of heat build up on the casing around the mounts area and this was picked up by his dyno operator. The crank is a new Mec Eur (or the new name for them now Tassinari or summat) and is running true, so not twisted. Has anyone got any thoughts on the vibration and / or heat build up and does anyone think they are connected?
by Adam_Winstone » Mon Jun 23, 2014 7:30 pm
Vibration could be caused by many things, however, the most common cause of heat build-up is over advanced ignition timing.
by sunrisemac » Tue Jul 01, 2014 10:02 pm
A bit late to post on this one but any chance the crank although running true could be out of balance?
sunrisemac
by Rich Oswald » Wed Jul 02, 2014 3:21 pm
I think we have tracked it down to non matching engine cones. I will report back soon,
Users browsing this forum: No registered users and 82 guests
