by kennystag » Sun Jun 07, 2015 2:54 pm
Hi All,
If I was to fit a battery on my GP what colour of wire on the junction box( on the frame) would I connect the positive from the battery to, this is just to try my electrics without starting the engine.
Stag
kennystag
by MK Monty » Sun Jun 07, 2015 3:46 pm
Normally the brown out of the regulator. Disconnect it and I would use a 5 amp fuse between the battery and the Brown so you dont cook anything. Obviously the negative to a good ground on the frame
MK Monty
by kennystag » Sun Jun 07, 2015 7:05 pm
Hi I do not have a regulator, just wires coming from the stator into the junction box.
Stag
kennystag
by MK Monty » Sun Jun 07, 2015 8:08 pm
Remove the stator wire to the junction box and replace it with your fused supply
MK Monty
by kennystag » Sun Jun 07, 2015 8:21 pm
Hi,
Remove which colour of wire.
Stag
kennystag
Users browsing this forum: Google [Bot] and 69 guests
