SX Horn cast badge 1968 - is this the right one
Postby Covboy » Thu May 14, 2015 8:41 am
Hi
I have bought a innocenti badge fron SR for my SX but it doesn't seem to fit very well . Is this the correct badge?
As you can see from the first photo - the horn casing is more curved than the badge , leaving a gap at either end. The badge looks like it would snap if I tried to bend it...
if this is the wrong one could some one please add a picture of the correct item
Re: SX Horn cast badge 1968 - is this the right one
Postby Paul Slack » Thu May 14, 2015 8:59 am
I believe the badge is correct.
Contact SR with pics and see what they say.
Paul Slack
Postby Covboy » Thu May 14, 2015 4:17 pm
Thank you Paul
Glad to hear at least I have he correct badge !
SR. have put a replacement in the post - I'll update this when I get it and it fits ...
Postby Covboy » Fri May 15, 2015 5:32 pm
SR. replaced the badge straight away, although the problem remains. I'm going to put my thinking cap on to work out how to make this fit acceptably.....
Postby Wack » Fri May 15, 2015 6:16 pm
Just gently bend it over something like a brush shaft with a hole drilled for centre peg
Postby Covboy » Fri May 15, 2015 6:24 pm
Great suggestion ! Thanks Wack. Why didn't I think of that ,,????
Postby CHRIS in MARGATE » Fri May 15, 2015 7:20 pm
Not right !
You shouldn't have to. Something is wrong; either the badge or the horncast.
Postby Dimitrios_231 » Sat May 16, 2015 8:42 am
I've fitted remade square badges in the past,the problem is on the badge.
They should be curved to fit better,the fitting was exactly the same as the one in the pictures.
Dimitrios_231
Postby dave411 » Sat May 16, 2015 9:06 am
Seeing as you have two,try warming one with a hot air gun and bend it into place.
dave411
Postby Kev Fox » Sat May 16, 2015 10:33 am
I have a badge that is definitely curved you can try.
Kev Fox
Postby Covboy » Sat May 16, 2015 11:51 am
Thanks kev - I'll pop over with mine to compare
Postby Covboy » Sat May 16, 2015 2:26 pm
Kev gave his spare badge and it fits! (Thank You)
Kevs is on the left, SR on right.
Postby Wack » Sat May 16, 2015 2:36 pm
Same here , original badge Image Image
