battery to provide temp power
Postby gaz_powell » Wed Jun 18, 2014 8:45 pm
Can someone kindly remind me how to connect an external battery to sorts lights out without having to start the bike.
Simplified electronic harness, standard cdi/regulator set up.
Gaz
Re: battery to provide temp power
Postby Wack » Wed Jun 18, 2014 10:18 pm
Connect battery + to the loom feed( usually brown) after removing from the regulator,the - to the engine/chassis .
Postby gaz_powell » Thu Jun 19, 2014 12:23 pm
Cheer Wack
That`s what i had in my head but thought i would check
Gaz
Postby Dazza » Thu Jun 19, 2014 10:04 pm
Use a battery charger if you have one..negative croc clip to the Frame and red clip to the brown (normally) once taken out of regulator...
Dazza
Postby gaz_powell » Fri Jun 20, 2014 9:17 am
go a fully charged 12v battery and a charger so should be okay
Gaz
Postby foremanbob » Fri Jun 20, 2014 11:19 am
Remember if you are using a car/motorcycle battery that you should have an inline fuse between battery and your loom....
You have the potential to melt your loom if you accidently create a short while you are working on it... A charger has a current limiter built in...
foremanbob
Users browsing this forum: No registered users and 51 guests
