R1 shocks
R1 shocks
Postby Callummal » Sat Feb 28, 2015 2:05 pm
Hi all what should be the correct spring for a R1 type shock to fit a ser 2 TV 175 thanks
Callummal
Re: R1 shocks
Postby rossclark » Sat Feb 28, 2015 4:14 pm
Without being rude, it depends what you weigh and whether you'll be using it with pillion and luggage or just solo.
Re: R1 shocks
Postby Callummal » Sun Mar 01, 2015 10:53 am
Hi solo and I weigh 14 stone thanks
Callummal
Re: R1 shocks
Postby Wack » Sun Mar 01, 2015 7:16 pm
Most go for a 225 lb spring but I prefer a 180 then use the adjusters to suit.
Re: R1 shocks
Postby Knowledge » Sun Mar 01, 2015 7:36 pm
I am just under 12st, and use the 180lb spring (if this helps)
Re: R1 shocks
Postby gaz_powell » Sun Mar 01, 2015 8:49 pm
10 stone 180lbs always travel on my own with a sizeable bag.
