Control cables
Control cables
Postby Peterp » Sun Jan 04, 2026 3:11 pm
Happy New Year to you all. Any advice on which cables, I need to change them on a standard TV series 3.
Peterp
Re: Control cables
Postby coaster » Sun Jan 04, 2026 9:58 pm
Buy a set from a reputable dealer, Camlam, MB, Glagow Lambretta, Just Lambretta
Re: Control cables
Postby Storkfoot » Sun Jan 04, 2026 10:48 pm
Bgm and CamLam do a copy of the original thicker front disc cable too.
Re: Control cables
Postby Peterp » Mon Jan 05, 2026 3:46 pm
Thanks both, without sounding thick, I see that a set of cables ranges from £27-£45, why?
I’m happy to spend and do the job right, even looked at the original types with false grease nipples for authenticity but is that overkill and waste of money?
Peterp
Re: Control cables
Postby Knowledge » Mon Jan 05, 2026 5:10 pm
It is a sensible question Peter.
A lot depends on how the cables were sourced. If you wanted manufactured to specific tolerances and made in the UK, then you would certainly pay a premium price. I have commissioned the manufacture of control cables in this country and they were brilliant, but expensive. However, you might find that you can get decent quality cables manufactured in India or China and obviously it would be cheaper.
I doubt if retailers are buying-in cable sets from suppliers and then bumping the price up to £45 to make a profit because they just wouldn’t sell them at that price. There must be a reason. Cables can vary in the quality of the ferrules used on the outer, the weave of the inner cables, the nylon lining (or not) and the addition of false grease nipples. Even the colour of the outer can be a factor.
So I haven’t got a definitive answer for you, but it might explain why some cables sets are more expensive than others.
Re: Control cables
Postby Peterp » Tue Jan 06, 2026 10:10 pm
Thank you again
Peterp
Re: Control cables
Postby nickw » Wed Jan 07, 2026 6:48 pm
The BGM pro do look and feel good. Not sure if I notice any difference in the ride. On fleabay the same seller has them at 33.95and 49.95 and there doesn't appear to be a difference apart from the price. Certainly worth shopping about
nickw
Users browsing this forum: No registered users and 60 guests
