GP flywheel
GP flywheel
Postby Littlewheels » Fri Apr 18, 2025 3:35 pm
Does anyone know if it's possible to use a GP 6 pole flywheel with a TV175 stator?
I want to convert to GP crank but retain the points system.
The hole in the stator is 28mm dia.
Littlewheels
Re: GP flywheel
Postby Fast n Furious » Fri Apr 18, 2025 7:38 pm
Series 3 flywheels have a longer taper boss that penetrates through the stator centre hole. GP flywheels have a non penetrating short taper boss, so it shouldn't be an issue.
Users browsing this forum: No registered users and 67 guests
