Leotech wrote:Has the trunion that goes through the tie rod and the swivel slipped down? I had one come to me where someone had put it together wrong and the trunion was through the swivel to far and it was catching on the casting where the engine number is and wouldn't go into 4th gear.
Wombat67 wrote:So after leaving it for a couple of weeks (other commitments and waiting for parts) I had another go at this today. Replaced the gear pivot and gear lever (both were worn and probably originals), inspected the tie rod (which seemed ok) and worked backwards from the gear shaft. With no tie rod and tie rod no cables attached to lever, engaged all 4 gears, though a few false neutrals. Attached cables and at the lever end can still engage all four gears however at headset/handle end can only engage 3 gears (with cables not attached to lever (or tie rod not attached to lever), handle moves freely). At the headset end it feels like there is slack in the inner cables yet they are relatively tight at the lever end, next step appears to be having a look at the cable routing/headset to see if anything is snagging or loose!!
Wombat67 wrote:Storkfoot - thanks for the tip, yep soon as I looked in the headset saw cable outer was out. Put it back in, checked other things people had suggested and took for a spin. All good so cheers to everyone who's suggested something.
