Littlewheels wrote:The Halite washer is ok for size but the innocenti retaining plate sits just about level without this fitted! The plate is 2mm thick and the recess to the top of the bearing is approx 2.4mm. The Halite washer is 1mm thick so whether it will compress sufficiently to enable clearance for the crank I don't know however I did also take time to measure the difference between the shoulder and crank web which is 1mm so as I say a lot depends on how much the washer compresses.
Toddy wrote:Littlewheels wrote:The Halite washer is ok for size but the innocenti retaining plate sits just about level without this fitted! The plate is 2mm thick and the recess to the top of the bearing is approx 2.4mm. The Halite washer is 1mm thick so whether it will compress sufficiently to enable clearance for the crank I don't know however I did also take time to measure the difference between the shoulder and crank web which is 1mm so as I say a lot depends on how much the washer compresses.
You can get different size halite gaskets from a dealer , a tip I got taught was put some solder between the plate and bearing without the halite gasket
Tighten the plate down then measure the solder to see what measurement you get then you know what gasket to fit
