Uni side casing
Uni side casing
Postby gizmo » Fri Aug 04, 2023 3:30 pm
Anyone else had bother with the Uni side casing been tight to get over the casing studs as if the holes in side casing are not in right spot. Tried on both a sil casing and a Spanish casing and both are tight.. Studs not central to holes in side casing.
gizmo
Re: Uni side casing
Postby Toddy » Fri Aug 04, 2023 3:57 pm
gizmo wrote:Anyone else had bother with the Uni side casing been tight to get over the casing studs as if the holes in side casing are not in right spot. Tried on both a sil casing and a Spanish casing and both are tight.. Studs not central to holes in side casing.
Do you mean a uni engine casing ? When you say the other two are tight ?
Re: Uni side casing
Postby gaz_powell » Fri Aug 04, 2023 4:04 pm
Yep, had to open them up to get it drop over the studs.
On both i have fitted, on SIL casings.
Just went next drill size on all holes
Re: Uni side casing
Postby gizmo » Fri Aug 04, 2023 4:51 pm
. Don't know how they fit on a Uni casing. Would hope they drop on perfect. Seeing Gaz has had same bother I presume they used a dodgy tape measure when they made mould. Thanks Gaz, I will do same
gizmo
Re: Uni side casing
Postby Rich Oswald » Fri Aug 04, 2023 5:29 pm
Mine went on a Spanish casing no problem.
Re: Uni side casing
Postby gizmo » Fri Aug 04, 2023 7:33 pm
Rich Oswald wrote:Mine went on a Spanish casing no problem.
. Strange isn't Rich how they can differ.
gizmo
Users browsing this forum: No registered users and 31 guests
