Stiff one !!!
Stiff one !!!
Postby Vega125s » Sun Nov 02, 2014 1:24 pm
Just got back from following the London to brighton veteran car run.During the last 20 miles the clutch became almost impossible to pull in and change gear, haven't checked anything yet but was wondering if anyone had any ideas? oh its a ts200 long stoke and a rocho clutch.
Vega125s
Re: Stiff one !!!
Postby Scooterlam » Sun Nov 02, 2014 1:26 pm
Fraying cable
Scooterlam
Re: Stiff one !!!
Postby Adam_Winstone » Sun Nov 02, 2014 1:50 pm
^... my first thought too.
Re: Stiff one !!!
Postby Wack » Sun Nov 02, 2014 7:54 pm
My guess is the steels have cupped, happened to every Rocho clutch I've fitted.
Re: Stiff one !!!
Postby Vega125s » Fri Nov 14, 2014 10:26 am
Turned out to be slight wear/kink in the outer cable from the steering stop.
The cable wasn't t that old , positioned behind the throttle wheel as per but on full lock catches the stop.
Many thanks for the answers gentlemen .
Vega125s
Users browsing this forum: Google [Bot] and 61 guests
