SIP Speedo
SIP Speedo
Postby spud » Mon Aug 11, 2014 3:38 pm
Looking to buy a SIP speedo, but a bit confused by the sensor options on the website.
They list various speed sensors KOSO SA 07, but as far as i can tell the only difference is the length of cable.
But they also list a bracket for KOSO 07 S type 8MM & 10MM & a bracket for KOSO 07 L type.
I don't see any different sensors?
Also different magnets as well!
So advice please, which is best to get to fit on a GP & where is the best place to fit the sensor (front or back wheel)?
cheers Spud :?
spud
Re: SIP Speedo
Postby spud » Mon Aug 11, 2014 5:47 pm
Eden, did you mount at front or rear & do you know what bracket you have?
cheers
Spud
spud
Re: SIP Speedo
Postby spud » Mon Aug 11, 2014 6:18 pm
don't look like the sensor is included any more :(
did you get the 3mm or 6mm magnet with yours?
spud
Re: SIP Speedo
Postby spud » Mon Aug 11, 2014 7:49 pm
Do you need more than one?
spud
Re: SIP Speedo
Postby rossclark » Wed Aug 13, 2014 1:05 pm
did mine like this, there was already a hole in the backplate that had been drilled for a scoop
Re: SIP Speedo
Postby Mike-bristol » Thu Aug 14, 2014 6:29 pm
Mine didn't come with a sensor , just been on the site and doesn't show in the pic so I seems they do them separately now.
Just ordered the bits , so any more pics would be helpful guys.
Mike-bristol
Re: SIP Speedo
Postby Timexit17 » Thu Aug 14, 2014 9:27 pm
Can you not use the speedo cable thats there already?
I.e. the speedo has a speedo cable socket as per the normal speedo -isn't this for the speed sensor via the normal movement of the cable or have I missed something?
Timexit17
Re: SIP Speedo
Postby Mike-bristol » Thu Aug 14, 2014 10:06 pm
Timexit17 wrote:Can you not use the speedo cable thats there already?
My cable is an Indian one so I'd have to change that anyway Tim.
Eden wrote:they were always an optional extra
It was a Birthday present form the Mrs , I must put in a complaint ;)
Mike-bristol
Re: SIP Speedo
Postby Timexit17 » Fri Aug 15, 2014 11:39 am
Cheers Mike, I am guessing cable only if it's Italian is ok then and forget the extra sensor?
Timexit17
Re: SIP Speedo
Postby LambrettaBerty » Wed Nov 05, 2014 5:33 pm
Eden wrote:Spud did you try searching the forum? lol
I posted this last week
no don't have a better pic but if I explain then the pic may make more sense.
the bracket you get with the sensor is bolted on at the bottom calliper bolt, the magnet is just placed onto the disk near to where the bolts are that hold the disk on to the hub, then the sensor is adjusted in or out on the grub screw until the end of it is within 5 - 10mm of the magnet.
get the one that has a slightly bigger hole than the bolt that goes in the calliper!
but im sure it all comes with the sensor
Hello Eden,
I'm new to the forum, I'm from belgium.
I'm trying to mount an external sensor for SIP counter and I see that in the photo you put you put the sensor directly opposite on the disc.
Could you take a picture of a face so see or look exactly the sensor.
With this active sensor, I think that we should not put magnets?
Thank you for your answer.
Berty
LambrettaBerty
Re: SIP Speedo
Postby Knowledge » Wed Nov 05, 2014 9:01 pm
Was there a resolution to the probelms encountered with running these speedos on a full DC system?
Re: SIP Speedo
Postby Norm » Thu Nov 06, 2014 3:16 pm
Is there anything special you have to do when wiring it up with a Wassel conversion? I know about the resistor plug, but something else?
Btw, if you have the active version of the Koso sensor, you don't need a magnet - any bolt head or nut will work, you just need to tell the speedo how many nuts equal one wheel revolution.
Norm
Re: SIP Speedo
Postby jonw » Thu Nov 06, 2014 3:52 pm
jonw
Re: SIP Speedo
Postby Norm » Thu Nov 06, 2014 8:37 pm
Thanks, I'll try and fit mine this weekend if I can brave the cold. I've got plenty of magnets stuck to various parts of my toolbox, so one way or another, I should be OK!
Norm
Users browsing this forum: Baidu [Spider], Google [Bot] and 28 guests
