Battery for Serveta Li150 S3
Postby GoonerKev » Fri Jun 18, 2021 12:53 pm
Can anyone tell me what size Battery to go for, on my Serveta Li150 S3 1980. Converting it to 12v DC, thank you.
Kev
GoonerKev
Re: Battery for Serveta Li150 S3
Postby missing lynx » Fri Jun 18, 2021 4:08 pm
Where's your battery tray is it in the normal place or behind where the toolbox door is blanked off? If it's in the normal place you want yb5l-b or 12n5-3b not sure of the type where the toolbox should be but they are larger in size
Postby GoonerKev » Fri Jun 18, 2021 5:29 pm
missing lynx wrote:Where's your battery tray is it in the normal place or behind where the toolbox door is blanked off? If it's in the normal place you want yb5l-b or 12n5-3b not sure of the type where the toolbox should be but they are larger in size
It has a battery tray in normal place, but looking at the location. Depth & height looks ok but width looks restricted by the tank bulging out !!!
******* Sorted ******* Noticed that the Tank straps are not in the correct position and making the tank too far forward. ;) ;)
GoonerKev
