gear selection
gear selection
Postby lammydave » Mon Mar 22, 2021 11:17 am
So, put my sx150 together, but have gear selection issues....
First run down the garden, all fine...BUT, couldnt get it out of gear... disconnected all cables and tried moving the gear selector at the engine end by hand..
Sometimes I can find gears, mostly not
So looks like a complete stripdown and take a look
layshaft?
Gear selector arm?
Suggestions as to where to start looking, please
Built a fair few from scratch, no issues, but this gearbox is untouched
TIA
lammydave
Re: gear selection
Postby Knowledge » Mon Mar 22, 2021 11:47 pm
This is not a diagnosis or a cure, but when I have had this problem I have been able to select neutral by twisting the grip into neutral WITHOUT USING THE CLUTCH.
Obviously, the scooter still has to be moving when you do this (such as rolling up to a junction or traffic lights), but it is usually easy to do.
What does this prove? Dunno
Re: gear selection
Postby lammydave » Tue Mar 23, 2021 7:41 am
Knowledge wrote:This is not a diagnosis or a cure, but when I have had this problem I have been able to select neutral by twisting the grip into neutral WITHOUT USING THE CLUTCH.
Thanks, Martin ... problem is now it's all over the place, even trying manually using tje tie bar .. sometimes i can get a couple of gears, others, it wont budge, sounds like there's a knocking when doing this from inside ... oh, well, stripdown today
lammydave
Re: gear selection
Postby MickYork » Tue Mar 23, 2021 8:23 am
one gear the wrong way round ?
Re: gear selection
Postby lammydave » Tue Mar 23, 2021 8:57 am
MickYork wrote:one gear the wrong way round ?
Fair shout ..... I'm going in, will report back later
lammydave
Re: gear selection
Postby hullygully » Wed Mar 24, 2021 4:37 pm
Too stronger selector spring bud?
Re: gear selection
Postby Warkton Tornado No.1 » Wed Mar 24, 2021 5:11 pm
hullygully wrote:Too stronger selector spring bud?
Good call & something I will admit to falling foul of. It's not necessarily the balls being over-sprung into the cursor making them 'stiffer' to move, but the cursor legs actually spring outwards that causes the issue.
Re: gear selection
Postby Storkfoot » Mon May 03, 2021 1:00 pm
I am curious. Did you get to the bottom of this problem?
