by superhooper » Sat Oct 31, 2020 10:58 pm
Hello peeps
Whilst refitting clutch plates/steels i noticed the bottom steel was worn/burred badly on the tabs. The other 3 steels seem to been virtually unaffected. Anyone think of a reason this should happen. All parts fit nicely into sprocket and the clutch was working ok.
Cheers Super
superhooper
by Knowledge » Sun Nov 01, 2020 3:19 pm
The bottom plates take the most force, so I am not entirely surprised.
It is recommended that if you fit a mixture of thick and thin steels in the clutch, then the thick ones go in first and the thin last.
by superhooper » Sun Nov 01, 2020 9:22 pm
Cheers Martin
superhooper
