by Paulusgnome » Sun Mar 15, 2020 1:01 pm
How can I remove the top bearing, before shot blasting the column?
Paulusgnome
by Andyf » Thu Mar 19, 2020 10:32 am
inserting a tube of slightly smaller diameter in the bottom of the column and tapping the tube is one method. PLEASE BE CAREFUL NOT TO STRIKE THE STEERING LOCK
Andyf
by dickie » Thu Mar 19, 2020 11:32 am
I use an internal bearing puller with slide hammer attachment. I must say, it's extremely hard work and I'd probably be better of using the pipe method AndyF mentions, but it's an option if you have one.
