I've been burnt on the last 2 stands I've purchased (both from well known manufacturers) and looking for an alternative that doesn't need to be 'massaged' or re-welded straight out of the box
vegansydney wrote:I'm seeking recommendations for a remade Series 3 centre stand. In particular, looking for one that has the brackets welded at the correct angle, and the spring bung in the right position. Not interested in anything stainless.
Warkton Tornado No.1 wrote:vegansydney wrote:I'm seeking recommendations for a remade Series 3 centre stand. In particular, looking for one that has the brackets welded at the correct angle, and the spring bung in the right position. Not interested in anything stainless.
Curiosity got a hold on me, so I browsed the eBay for sale section.
I had not realised quite how the situation had become, even with such an item that is mostly not under any great strain as it is the frame that tends to suffer, the 'stops' on the stand itself being reasonably easy to re-align. That said, WT No2 used to fit adjustable screws to his stops, which I used to think a bit gash. The last time his scooter got left with me, I straightened out his stand properly. Not that he noticed![]()
I wonder if there is, therefore, a market for used OEM stands that have had their stops re-aligned......
