Pompeydave wrote:Hi Storkfoot, running a BGM big box mk3. Very conservative timing at 16 BTDC. No air filter, just run it through an empty air box.
hullygully wrote:why 16 deg btdc bud?
Storkfoot wrote:Pompeydave wrote:Hi Storkfoot, running a BGM big box mk3. Very conservative timing at 16 BTDC. No air filter, just run it through an empty air box.
Each engine is different but, given your set up compared to mine, you probably need a bigger pilot than a 48 but smaller than a 53. If you have to screw the air mixture screw in, you are weakening the mixture and, if it still won’t tick over, it’s worth trying a smaller pilot, say a 50 or 51.
Then warm the engine up properly and spend some time adjusting the air mixture screw, listening to whether it likes being richened or leaned off. Also, look at the smoke coming out of the exhaust and whether, whilst blipping the throttle to no more than 1/4 throttle, the engine responds readily and doesn’t hang up when coming back down to a closed throttle position.
This is, of course, assuming that you don’t have a small air leak.
Pompeydave wrote:Thanks. Are the BGM jets a good copy of the Dellorto originals?
Users browsing this forum: No registered users and 3 guests
